Posted by Dale_MN on October 18, 2011 at 19:44:24 from (208.38.113.117):
In Reply to: M clutch posted by Dale_MN on October 14, 2011 at 18:32:54:
Updating, I pulled the belly pump this afternoon and had a chance to visually inspect the clutch. I'm not familiar enough to know how things should look but the release bearing assy moves easily and engages the 3 levers when the clutch is depressed (1st 2 pics, clutch depressed and clutch out). I assume that means the friction disc is stuck to the drive plate. Is this a symptom of a clutch that in the near future will need to be rebuilt? Also, the seal on the input shaft for the belly pump has been leaking. It looks like a the seal and bearing are held in place by a casting. Removing the cap bolts and casting would give access to that seal, or is it more complex than it looks?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
