Re: belly mounted sickle mower
Posted by gene b on August 24, 2000 at 20:24:27 from (63.25.166.238):
In Reply to: belly mounted sickle mower posted by Jess on August 24, 2000 at 06:29:57:
probably without a doubt it will not fit look at it you should be able to see that the other tractors are quite diff in that area
Post A Followup
: Re: Re: belly mounted sickle mower
