Re: M with Heisler od pops out of low side
Posted by D Slater on October 19, 2011 at 02:45:30 from (184.15.3.93):
In Reply to: Re: M with Heisler od pops out of low side posted by IAJosh84 on October 18, 2011 at 05:48:00:
Two sets of gears for low and high range drive are in constant mesh. there's a sliding shift collar that locks one set of the gears (on gear ID) to the lower transmisssion shaft depending on the range shifted to. There's springs and popet balls to hold shift sleeve in place when shifted to ranges. Probably have to get in the transmission to see the problem. May be able to look in the belt pulley gear box opening to see if its shifting fulley into range.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
