Hold your hand over the throat of the carburetor while a helper try's to make an engine start. If there's not much suction on your hand is an indication of low manifold vacuum. Make sure your intake manifold is tight. Open your main jet adjusting screw near the bottom of the carb. I would check the flow of gas from your tank to the carb. If there's good flow from the tank remove the tube fitting where your gas line connects and check for a plugged screen behind that fitting. If none of this helps remove that main jet adjusting screw and blow out the jet with air pressure. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
