Re: re: minimum octane requirements
Posted by mkirsch on October 19, 2011 at 12:41:06 from (64.80.110.75):
In Reply to: re: minimum octane requirements posted by tractor300 on October 19, 2011 at 08:34:19:
It's not the carburetor that's the issue.
It's the cylinder pressures and temperatures in the later HIGH compression IH gas engines. That is, any post-1958 tractor starting with the 460/560 series.
The old pre-1958 engines are LOW compression engines, and run fine on 87 octane. Higher octane is a waste of money on these.
Lean, rich doesn't make a lick of difference. The low-octane fuel will still go *BANG* too soon in the high compression engines. It's the fuel, not the mixture.
Octane doesn't make any difference in modern cars because there is a computer, a bunch of sensors, and a bunch of controls that change timing, fuel mixture, etc. to compensate. These old engines have one "sweet spot" where they work. Performance and longevity fall off drastically when you start messing with that sweet spot.
