Re: 886 issues
Posted by Farmerdoug on October 19, 2011 at 15:26:03 from (97.90.227.11):
In Reply to: 886 issues posted by Farmerdoug on October 18, 2011 at 17:29:11:
Thank Jim and Owen for your replies. I am going to try to overfill the oil as Jim recommended to see if that takes care of the problem. Is there a way to see if the dumpvalve is sticking as Owen suggested? Is it possible to fix it if it is withought completely going through the MCV or is a rebuild reccommended? I am going to look at it this weekend and try a few things out and will report back most likely with more questions. Thanks again guys- Doug
