Re: farmal H
Posted by LenND on October 20, 2011 at 14:27:21 from (74.207.160.118):
In Reply to: farmal H posted by neklone on October 20, 2011 at 10:20:35:
Yes! I use one on my H . Works good. I used the belly pump for the hydraulics. Run ahose from belly pump to double acting valve and then a return hose back to pump. I put a tee in the fill pipe for the pump and attached the return hose. Then run a hose from control valve to the cylinder and one back to the control valve.
