Re: Exhaust Pipe - Exhaust manifold
Posted by Armand Tatro on October 20, 2011 at 15:56:41 from (98.227.26.140):
In Reply to: Exhaust Pipe - Exhaust manifold posted by JRSutton on October 20, 2011 at 15:36:39:
This is one on those times if it's not broke DON'T MESS with it! As long as it is firmly attatched to the exhaust manifold and you can put a muffler on the pipe I would not mess with it because you might/will/could break the exhaust manifold and then that could be a real pain to change out and expensive and maybe hard to find. If you want to make the pipe look better see if you can a high tempture black paint because the pipe is black pipe. Armand
