Re: 3588 radiator replacement
Posted by Dmack on October 20, 2011 at 16:45:13 from (70.130.153.110):
In Reply to: 3588 radiator replacement posted by Shane O'Connor on October 20, 2011 at 09:09:27:
I too have completed this task. The worse part was getting the blasted hood off. Myself and a big strong lad lifted it straight up after undoing about a dozen bolts on each side. It was alot easier than splitting that rascal and replacing the pins and bushings.
