You have the right tube because it would take forever to pump the liquid ballest thru a stamdarded car or bike tube valve. Look at where the valve stem comes thru the hole. There is a nut there that holds the valve stem firmly to the rim. Now about 1/2 to 1 in. towards you you will see a connection that can be unscrewed. Takes a plires or visegrip to loosen that connection than you can unscres by hand. The part thart that you hold in your hand ( about 1/2In. dia. and about 1-1/2in. long) is what you need to replace. What you replace was the valve core thae fits inside the piece that you are in your hand. Talk to your tire shop and they can show you the pieces (parts) that I am talking about. A water valve is totaly different than the common car or bike valve stems that you are used to. This is the best I can explain it without a picture. Armand
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
