Posted by The tractor vet on October 20, 2011 at 21:11:43 from (75.19.123.11):
In Reply to: 806 engine noise posted by 450dieselfan on October 20, 2011 at 21:00:43:
when adjusting the valves you need to pay attention to the ware on the rocker arm as they do not ware even and there is always a little rocker arm hanging over the valve stem and when you stick the feeler gauge between the rocker arm and the valve stem you get a bridging and this will throw your set off and you will have a few loose ones . So go back over them again and look real close and you will see what is going on . Now IF you get it down and ya still have noise then you may have a guide issue . Also take a long handle screw driver and place the end against the block by each piston and put your ear to the handle and listen you may also be hearing piston slap .
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
