Posted by Richard S. on October 20, 2011 at 22:22:54 from (70.2.81.97):
I have a 986 (late 1978) tractor that has a major problem and I need some advice and or opinions from anyone. It has worn out bearings in the Range Transmission and a gear that is missing 2 teeth. Mechanic says that it will cost 4 - 5 thousand to overhaul. However, if some of the problems in the range transmission have caused damage in the Speed transmission, then that too will need to be overhauled. Total cost of about 10 thousand.
Should I junk it or do the overhauls.
I like the tractor, engine starts and runs great with plenty of power. Has a new water pump, alternator, gauges. Cab and air are not functional - windows need to come out. The tractor is not very pretty because it has quite a bit of rusted out sheet metal. Rear tires in bad shape but front ones excellent
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
