Re: centrifugal advance timing for C-135
Posted by D Slater on October 21, 2011 at 08:23:41 from (184.15.3.93):
In Reply to: centrifugal advance timing for C-135 posted by Jim Huber on October 21, 2011 at 07:28:12:
Think some of the C135 used a two letter distributor code. May want to double check to see if a letter follows the A if thats how you identified it. H tractors came with 40 degree advance, but could be changed down through the years. Not sure about power units or RPM the engine is set for. Tractors with C135 were around
25 degrees or less max.
