Re: Fast hitch Rototiller for SA thru 140 ???
Posted by mkirsch on October 21, 2011 at 10:26:16 from (64.80.110.74):
In Reply to: Fast hitch Rototiller for SA thru 140 ??? posted by BMD on October 21, 2011 at 08:04:56:
The Howard CUB rototiller includes a speed reducer gearbox that bolts in between the transmission and final drive. It cut each gear's speed in by 2/3 or better.
For a tiller to work on a Super A or 100, it would need a similar speed reducer gearbox.
