governor farmall 404
Posted by farmall 404 on October 21, 2011 at 12:03:29 from (207.62.88.11):
The throttle on my farmall 404 moves freely. However, the engine does not accelerate. From what I"ve found it could be the spring inside the governor is broken or came off. Is there anything else that would cause this problem?
