Re: does the gasket kit here for the c have the crank seal?
Posted by Bob on October 22, 2011 at 08:39:36 from (64.255.159.192):
In Reply to: Re: does the gasket kit here for the c have the crank seal? posted by oldiron29 on October 22, 2011 at 04:03:25:
Here's the link to the parts lookup. You need to enter it as "Farmall C" as "C" alone doesn't bring up the parts cat.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
