Re: 300 will not move/roll.Its STUCK!
Posted by Janicholson on October 22, 2011 at 15:07:08 from (96.24.99.126):
In Reply to: 300 will not move/roll.Its STUCK! posted by Copperdog on October 22, 2011 at 14:54:21:
Jack it up off the ground so you can move things.
Try each wheel (if one turns forward and the other
backward, the finals and differential are at least
free. Look in the cover for the belt pulley
(assumes it is a Farmall) and watch the transmission
to see if the gears move at all (block one wheel to
drive a back and forth motion into the trans). It
could have a broken shifter fork, allowing it to be
in 2 gears even with the rails aligned. Jim
