Re: followup on my early 48 C, need some parts help
Posted by soundguy on October 22, 2011 at 15:47:26 from (184.247.8.27):
In Reply to: Re: followup on my early 48 C, need some parts help posted by CharlieNJ on October 22, 2011 at 04:33:15:
oil pressure is great.
I'll need to get that bearing splitter, and then the 1/" bolt hardware.
I didn't see threads inthere, but may be clogged with dirt,e tc.
thanks
soundguy
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
