Re: 300 will not move/roll.Its STUCK!
Posted by D Slater on October 22, 2011 at 17:25:17 from (184.15.3.93):
In Reply to: 300 will not move/roll.Its STUCK! posted by Copperdog on October 22, 2011 at 14:54:21:
If the brakes are removed, pull the bull pinion shafts out and see if the wheels turn. If not you realy have a problem unless its cold enough to freeze ice at that location. To pull the bull pinions, pry the plate the inside brake contacts and pull shaft out. If stuck there's a bolt hole in the shaft end so a slide hammer can be used. With the right setup the shaft and plate can be removed at the same time. Old brake disc on shaft and a pry bar will work also.
