Re: Found the compression problem with the H...
Posted by sflem849 on October 22, 2011 at 18:28:27 from (69.197.84.39):
In Reply to: Found the compression problem with the H... posted by Crazy Red Power in SE-WI on October 22, 2011 at 18:22:35:
It's all good. I'm going to reuse a frest head gasket on my WD-9, but that is a $175 head gasket. :shock:
