I am very curious about this, wonder if its just stuck in 2 gears, 300/350 were improved over the H/Super H in that you can remove the housing that the shift lever is mounted on the top of the deck with 3 bolts, then you can look down into shift lever notchs & see if they are lined up with each other in neutral. Older IH tractors are notorious for this as they wear the end of shift lever. Hope it is not serious.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
