Re: W-6 wiring
Posted by Janicholson on October 22, 2011 at 21:35:43 from (96.24.99.126):
In Reply to: W-6 wiring posted by rls_ia on October 22, 2011 at 18:02:29:
The light is attached to a pipe which is attached to a flange that bolts to the rad shroud. The wire goes through the center of the pipe from inside the shroud. The pipe and bracket provide the ground path for the light to work. I do not understand what insulation is needed. Jim
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
