It is difficult to give rusty bolt removal advice when the part does not """Need""" to be taken apart. Cutting off the heads of the bolts, leaving the shank to work with sticking out of the assembly is far easier than twisting them off just below the surface of the threaded portion in the second casting. But it is your call. The way to assess the floor of the exhaust to intake junction for cracks is to plug the intake port from the carb flange with a rubber plug, then lay it on its back so the ports are all facing up and pretty level then filling the intake ports with water. if they fill and none comes out the exhaust runners it is pretty clear there is no crack. Visual checks on the flap condition is probably harder. Mirrors or a bore scope might help, wjth good light, but difficult. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
