Re: 300 will not move/roll.Its STUCK!
Posted by CNKS on October 23, 2011 at 08:14:14 from (216.144.104.128):
In Reply to: 300 will not move/roll.Its STUCK! posted by Copperdog on October 22, 2011 at 14:54:21:
Just go to the effort of pulling the trans cover. If it turns out to be something simple, you need to clean out the inside anyway. I have a Super H that I "restored". Removing the trans cover is part of the procedure. Mine had pits in the bull gears from sitting in water for so long. I did not replace them as I assumed they were not that bad, but I cleaned everything up. If you get it to work before then some just put in kerosene, run it around for a while and drain it. IMO that procedure does not get it really clean.
