Re: Fuel octane recommendation
Posted by rustyacresnd on October 23, 2011 at 08:25:15 from (69.84.76.166):
In Reply to: Fuel octane recommendation posted by D Slater on October 21, 2011 at 15:53:07:
Just my $0.02 worth. I work as a tech in a new car dealership. I can't recall any of our vehicles running only 8.5 compression. Most of them are in the 9.5 to 11.5:1 range and recommend 87 octane. These modern engines also put out up to 400+ HP. Even the 4 cyl can get close to 300 HP with the factory turbo. Of course they also use variable valve timing and ignition timing to control detonation. I also remember detonation issues on cars of the mid 70s through the mid to late 80s because they were trying to raise temps and lean out mixtures to reduce emissions. Those things would "ping" with 8:1 compression on 87 octane and put out 110 HP with a 350 V-8. Anyway I'll keep running 87 in my M's since I don't use them that hard anyway and haven't had any problem yet.
