Re: 27v hook up help
Posted by Brownie 450 on October 23, 2011 at 12:36:20 from (66.43.241.198):
In Reply to: 27v hook up help posted by brian1855 on October 22, 2011 at 20:51:21:
Ours doesn't have a trailing wheel. It mounts on brackets bolted on the axle housings. A long solid rod from the touch control to a lift link on the mower provides sickle bar lift.I'll try to get a pic later today. If it turns out, I'll send it along.
