I have used a belt in the past to start engines. First time I went to start the WC, one of the rusted rims gave up and fell off. Jacked it up and tryied using a JD 520, but the bearing in the pulley was going out so you couldn't get it tight enough and get it out of gear. Had to get the 8N ford and a come-along to winch the 520 backwards so I could get the tension I needed to get the belt turning. You do have to get them lined up nice and square and get some tension on the belts to use them. Pulleys have a crown so once everything is in place and tight the crown helps keep the belt traking to the center of the pulley.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
