Re: Boost hydraulic output
Posted by RPM1941 on October 24, 2011 at 09:08:07 from (173.24.196.59):
In Reply to: Boost hydraulic output posted by ridgelane on October 23, 2011 at 21:45:02:
They put 3 different GPM (gallons per minute), std & most easy to find is 12, next was 15, & the highest was a 17, you can find them in any variation from 460 thru 1586, you might try just the high pressure cartridge that screws in the side of the seat casting, they made 4 variations in high pressure limit, 1750 psi, 2000 which is probably what your 1066 had originally, 2250 & the highest was 2500, they are all marked with at least the part number.
