Re: Super M clutch or tranny problem?
Posted by John M on October 24, 2011 at 12:59:20 from (68.115.194.228):
In Reply to: Super M clutch or tranny problem? posted by bbbuddy on October 24, 2011 at 12:49:36:
Common problem, the end of the shifter is wore, and now its hung in 1st or in 2 gears. Cure is to build up the end of the shifter by welding and cutting it back down. Then the shifter rails need to be re-aligned back in neutral, and the shifter re installed.If youll search the archives, youll find all the info on fixing this.
