Re: Farmall C with Fast Hitch
Posted by Lmack on October 24, 2011 at 13:28:45 from (74.176.39.65):
In Reply to: Farmall C with Fast Hitch posted by Dean Olson on October 23, 2011 at 16:47:33:
third party image
WE had a 200. This part is not farmer made but is OEM by IH. The kit to add the fast hitch to the C has to be an add on product from IH. The stationary level bar shown was used when any rear mounted implement was used in conjunction with front mounted cultivators or planters. It locked down the level device leaving the front rock shaft to control the front implements without affecting the rear gangs. The draft tube would also have been placed in the stationary position. The adjustable draft tube and level device was only mounted in the movable position when plowing. Take a look at the picture below.
