200 Brake Oil Seal
Posted by Lmack on October 24, 2011 at 13:50:57 from (74.176.39.65):
Both of the oil seals (Both Sides) need to be replaced behind the brakes. What am I getting into when I do this? Yes I am talking about behind the brakes because the disk are wet with oil. Is it a big job and do I need any special equipment? What parts should I have before I open it up? Same questions about the oil seals at the ends of the rear axles?
