Hendrik - The fundamental "tone" (frequency) of an engine's exhaust is exactly as you describe. And the frequency for different engines with the same number of cylinders running at the same RPM will be identical as you mention.
HOWEVER engine displacement, exhaust port design, exhaust manifold geometry, exhaust pipe diameter/length and other factors generate all sorts of harmonics of the fundamental frequency. This causes engines with the same number of cylinders and running at the same RPM to have entirely different "voices".
Example: A straight 6 with with a center outlet manifold (Dodge/Plymouth flathead 6) sounds very different from a Continental straight 6 with its manifold outlet between the #1 and #2 cylinders.
End outlet manifolds, split manifolds, etc similarly result in dramatically different exhaust notes from otherwise identical engines.
Incidentally as a kid I could distinguish just by sound IHC, Mack, White, Chevy/GMC, Dodge and Reo gas truck engines. Likewise Farmall, Allis-Chalmers, Minnie-Mo, Ford, etc. 4 cylinder tractors. Hearing these engines run at antique truck and tractor shows brings back fond childhood memories(!)
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
