Re: C, day 1 progress
Posted by Lmack on October 24, 2011 at 19:30:07 from (74.176.39.65):
In Reply to: Re: C, day 1 progress posted by brian1855 on October 24, 2011 at 19:07:19:
All well and good but you may need four hands if the nut to the rear turns in the slot (mine does) which implies that the guides are stripped out. I usually end up with a bar under one arm, one hand holding a open end wrench on the back nut and a thin open end on the front bolt. It often takes more than one try to get the belt tight.
