Re: H Front End Wobble
Posted by BillyinStoughton on October 25, 2011 at 07:05:59 from (64.73.44.244):
In Reply to: H Front End Wobble posted by George rausch on October 24, 2011 at 17:06:02:
Like the guys said below, I would check the runout also. Sometimes just rotating the tire with excessive runout a 120° cures the problem. It can also be compensated for by installed a shim (washer) between the rim and hub. It's simple enough to check. I had the same issue with one of my H's. Good luck with it!
Billy
