If you are saying the engine won't turn even with the clutch pushed in there's more of a problem than the transmission locked up. Engine should still crank with clutch released even if the transmission is locked. Unless there's a problem with the clutch not releasing or maybe the starter jamed in the flywheel when trying to start tractor. It would unjam when the engine was removed if so. Like the other posters said the transmission is probably in two gears, the shifter jumped slots and let transmission get in more than one gear. If he gets the transmission fork slots all lined up in neutral the shaft the clutch plate goes on to drive transmission should turn by hand.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
