Re: pulley broke, need options
Posted by Dean Olson on October 25, 2011 at 14:45:36 from (166.205.13.33):
In Reply to: pulley broke, need options posted by soundguy on October 25, 2011 at 12:27:36:
I cut a hole in a piece of 1/2" plate and them cut that in half. Then welded the halves to the broken pulley and to each other. Gave a good place for the puller to grab and the heat from weld made it come right off.
If its in fact epoxied on maybe the heat will soften that up.
My other SC has a bolt through the pully & end of the crank, by PO. No key and the end crank worn enough so as new pulley wouldnt go on tight. I put it back like I found it. No issues so far.
