Re: pulley broke, need options
Posted by soundguy on October 25, 2011 at 16:15:55 from (173.107.97.122):
In Reply to: Re: pulley broke, need options posted by CNKS on October 25, 2011 at 15:09:37:
i had the seperator where the base of the lips flat were holding on near the base of the hub, not the flange. hard to see from this angle, but it actually ripped the flange clear off the hub at the point the flange contacts the hub.. the only lip left was in one side recess where the seperator does not touch on either side.
I'm pretty certain i had the seterator doing it's best to NOT contact the pulley but at the base so as not to break it. the thru bolts int he seperator diod not deform or bend, and the seperator did not bend / was not damaged.. the hub simply gave away right where it ceases being a flange and becomes part of the face of the hub.
soundguy
