Re: pulley broke, need options
Posted by Janicholson on October 25, 2011 at 16:31:59 from (67.72.98.45):
In Reply to: pulley broke, need options posted by soundguy on October 25, 2011 at 12:27:36:
Were it mine I would put the splitter back on and the jack against the partially threaded in center bolt (leaving a 1/8" gap between the bolt head and the crank spiral.) Then I would heat the hub near red with a flame wrench. It will pop the hub before it gets extremely hot. The seal is toast any way. Easy and not hard on parts. By the way you did it all correctly. Putting a bit of heat and 50 Pounds less force would have done it. Jim
