Re: Super M clutch or tranny problem?
Posted by Janicholson on October 25, 2011 at 17:00:00 from (67.72.98.45):
In Reply to: Re: Super M clutch or tranny problem? posted by bbbuddy on October 25, 2011 at 09:43:13:
You are saying the tractor engine drives the rear wheels with the clutch down (pushed in).
If this is the case the clutch could be stuck to the flywheel. In which case it is easy to fix when apart. The pilot bearing in the engine flywheel to clutch shaft could be jammed and driving the clutch shaft, but that is about it, and it is now removed from the FW.
Is this tractor a Super M TA. If it is it is a whole different ball game. Stuck in gear can be a TA clutch adjustment. Especially if the tractor is on a grade that tries to make it coast backward. If the lever is stuck in 1st, the way to get it free is to push the rear tires forward to relieve the pressure on the Trans. Jim
