Soundguy,You can try this to get it off the crank.Turn the crank till the keyway is at 12 o clock,then use a 7" grinder with a hard kwick flat disk on it and grind it down to the key.It shouldn't take long to grind it down to the key.Then with the heat from the grinding it should knock off tapping it with a hammer.With no damage to the crankshaft.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
