Re: 100 Transmission Leak
Posted by JRSutton on October 25, 2011 at 18:34:44 from (75.130.109.233):
In Reply to: Re: 100 Transmission Leak posted by ERIK Dekeyser on October 25, 2011 at 18:28:40:
That was going to be my answer - it's over full.
The trans takes a suprisingly small amount of oil (think it's 4 quarts or so - can't remember exactly)
The seals may be (probably ARE) bad, but for the most part, that shouldn't be a real problem as the oil level should be lower than the seals.
Water can get in there raising the level - or if you've "topped it off" recently, that could do it to.
Sometimes it can be very full for a long time, and the seal finally gives out under some heavy use and looks like a new problem.
I'd drain it and fill it properly - see how it goes after that.
