Re: pulley broke, need options
Posted by rustcollector on October 26, 2011 at 09:19:15 from (67.142.161.32):
In Reply to: pulley broke, need options posted by soundguy on October 25, 2011 at 12:27:36:
Soundguy,
Crankshaft on that engine should be 1.250 inches plus what was left for interference fit if that is the vintage you have. I would saw or grind down to about 1/16 inch of the shaft on each side and retry the puller. Pulley may split, but you will not be able to saw where the seal rides. Use the key slot for the first cut and if you go too deep, it will be into the key. Key should stick up about 1/8 inch. Better luck with the remainder of the project.
