Re: Cub manifold
Posted by glennster on October 26, 2011 at 14:51:09 from (76.224.4.21):
In Reply to: Re: Cub manifold posted by Skipster on October 26, 2011 at 14:29:38:
dont plug the hole, its there to drain rain water and condensation out of the manifold. use some compressed air and blow some in the hole with the muffler off and see if you get water spraying out of the exhaust outlet. if so blow as much out as you can, then let the tractor run and get good and warm to dry it all out. may want to pull spark plugs and check the cylinders for rust.
