Re: Wood chipper on Farmall Super MTA
Posted by janicholson on October 26, 2011 at 15:20:08 from (96.24.99.126):
In Reply to: Wood chipper on Farmall Super MTA posted by Ellis Kinney on October 26, 2011 at 06:45:41:
my mention of a damened drive shaft included several options (Lovejoy style couplers were not on the list) Mid 1960s Ford drive shafts on automatic transmissioned cars have a rubber torsion damper between two different sized tubes. these could be fabed into a TO shaft for yours at any drive line shop, and obtained for a few bucks at a junk yard. The woods dampener is also a valid solution, as are other similar components. Good luck, Jim
