Re: Found the compression problem with the H...
Posted by M Diesel on October 26, 2011 at 16:57:06 from (12.24.61.12):
In Reply to: Found the compression problem with the H... posted by Mike Bock on October 23, 2011 at 19:15:56:
I pretty much do the same, especially on the same engine with a recent gasket. I have to reuse them on my old large IH gas start diesels. At $300 apiece "IF" you can get them it isn't a real hard decision. Granted they use fire rings but they work fine. And I use anti seize. Copper coat isn't about being sticky. It is about being a grease during the critical time when the gasket is settling in.
That H head has been loose for a long time. Not warped. Loose. With sloppy bolting those surfaces are probably warped by now too, but a new gasket will likely seal it up anyways. It's just an H.
That missing piece basically went out the exhaust quite a while go.
