Re: Cub issues
Posted by SouthernFarmall on October 26, 2011 at 17:54:51 from (71.48.204.136):
In Reply to: Re: Cub issues posted by janicholson on October 26, 2011 at 16:15:50:
How do I check the height of the water? There is a round piece inside the radiator that prevents me from seeing very far into the radiator. In addition, when you say "bottom of the fill neck", do you mean where the filler neck begins to form the top of the radiator? By the way, I also added about 1 gallon of water/antifreeze recently, because the Cub had begun to steam from the overflow. I don't know how long it took for the tractor to lose that much fluid, but no coolant had been added recently. Thanks!
SF
