Re: Cub issues
Posted by mkirsch on October 27, 2011 at 05:29:42 from (64.80.110.75):
In Reply to: Cub issues posted by SouthernFarmall on October 26, 2011 at 16:01:59:
The cub is most certainly NOT a pressurized system! Put a non-pressurized cap on the radiator (available at Tractor Supply).
You can see in the radiator just fine if you look AROUND the tube at an angle with a flashlight. If the coolant level is above the fins with a cold engine it is fine.
