Re: Cub issues
Posted by screwstick on October 27, 2011 at 07:25:58 from (174.24.0.234):
In Reply to: Cub issues posted by SouthernFarmall on October 26, 2011 at 16:01:59:
Ron, Matt and Gene are right. Overheating too quickly, remove the lower water neck and flush both the bolster and as much as you can get to in the block. Toss the pressure cap. Check the spring on the governor, it may be broken. Also check the rod that goes into the side of the governor, there is a woodruff key in there that wears and causes slop on the shaft and limits throttle control.
....and hey Ron! Great to see you posting! Hope you are doing well!
