Re: 656 farmall diesel hard to start
Posted by Owen Aaland on October 27, 2011 at 07:37:20 from (216.47.32.147):
In Reply to: 656 farmall diesel hard to start posted by stark on October 27, 2011 at 06:45:16:
What did you do to the head when you had it apart? If you had the valves and seats resurfaced without doing anything else you just made any starting problems worse. Those engines are very sensitive to valve recession in the head. The closer you keep the valve heads to .003" recession the better they will start. In most cases when an overhaul is done the seats need to be replaced in the head. By replacing the original valve seats with thicker ones you can often get the correct recession and still use the original valves.
