Posted by screwstick on October 27, 2011 at 08:12:05 from (174.24.0.234):
In Reply to: Cub ignition posted by RGMartin on October 27, 2011 at 08:01:19:
You can use the mag as a distributor. Mount the external coil, run a hot lead to one side of the coil, and a wire from the other side of the coil to the post on the side of the mag. You will need a two post kill switch that will allow you to remove power to the coil. If you do this, make sure that the mag coil is no longer connected to the points (cut the wire). The ignition wire would then go to the external coil vs. the mag coil.
Or, you can purchase a new mag coil and be done with the fix and keep things original. A bit more expensive, but easier fix.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
